Resets all PIM settings on an IPv4 or IPv6 module, or on one or all VLANs, to their default values.
ipv4 | Specifies the IPv4 module from which PIM is to be unconfigured. |
ipv6 | Specifies the IPv6 module from which PIM is to be unconfigured. |
vlan_name | Specifies the VLAN from which PIM is to be unconfigured. |
tunnel | Specifies the tunnel which PIM is to be unconfigured. |
tunnel_name | Specifies the tunnel name. |
border | Specifies the border. |
If no VLAN is specified, the configuration is reset for all PIM interfaces.
If you unconfigure PIM globally using the unconfigure pim {ipv4|ipv6} command, you also unconfigure PIM-SSM, removing PIM-SSM range and SSM setting for PIM all interfaces. Static RP configuration is not removed in this case.
The following command resets all PIM settings on the VLAN accounting:
unconfigure pim vlan accounting
The ipv4 and ipv6 keywords were added, giving an option to support this functionality in IPv6 as well, in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
